Create a non bootable image on RT1060
rasm
I have HAB and XIP enabled on RT1060. I would like to use two images, one bootable and one non bootable. The second one would be then loaded from the first one. I can create the bootable image fine with elftosb tool but not the non bootable. How is it possible to create a non bootable image with elttosb (or some other) tool?
gusarambula
Hello Rasm,
We do not have an example with that exact implementation.
You may see on the following Knowledge Base document the steps to generate a bootable image. On of the intermediate steps is generating a binary from your .elf file.
https://community.nxp.com/t5/i-MX-RT-Knowledge-Base/Generating-a-Bootable-Image-for-the-RT1050/ta-p/...
I hope that this information helps!
Gustavo
gusarambula
Hello Rasm,
Gustavo
