rt1052开启HAB后,使用nxp mcu bootutility串口启动无法连接flashloader
1,678件の閲覧回数
Evanee
看控制台信息,感觉flashloader已经签名成功了,并且下载、跳转到芯片,不知道为什么连接不上。我使用的是核心板和底板组合的板子,换一个没开启HAB的核心板,可以正常下载,说明flashloader本身没有问题。打开自动生成的为flashloader签名的bd文件,没看出什么问题,希望寻求帮助。
控制台信息如下:
executing: D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\sdphost -t 50000 -p COM22,115200 -j -- error-status
toolStatus: 0
commandOutput: {
   "command" : "error-status",
   "response" : [ 4042322160 ],
   "status" : {
      "description" : "305411090 (0x12343412) HAB enabled.",
      "value" : 305411090
Executing: D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\sdphost -t 50000 -p COM22,115200 -j -- read-register 1075790864 32 4 D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\vectors\readReg.dat
toolStatus: 0
commandOutput: {
   "command" : "read-register",
   "response" : [],
   "status" : {
      "value" : 305411090
Executing: D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\sdphost -t 50000 -p COM22,115200 -j -- read-register 1075790880 32 4 D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\vectors\readReg.dat
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
Executing: D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\sdphost -t 50000 -p COM22,115200 -j -- read-register 1074757636 32 4 D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\vectors\readReg.dat
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
Executing: D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\sdphost -t 50000 -p COM22,115200 -j -- read-register 1074757660 32 4 D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\vectors\readReg.dat
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\elftosb4\win>"D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\elftosb4\win\elftosb.exe" -f imx -V -c "D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\gen\bd_file\imx_flashloader_gen.bd" -o "D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\gen\bootable_image\ivt_flashloader_signed.bin" "D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\src\targets\MIMXRT1052\flashloader.srec"
CSF Processed successfully and signed data available in csf.bin
        Section: 0x14
        Section: 0x15
        Section: 0x16
        Section: 0x18
        Section: 0x19
        Section: 0x1a
        Section: 0x1f
        Section: 0x21
iMX bootable image generated successfully
Executing: D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\sdphost -t 50000 -p COM22,115200 -j -- write-file 539001344 D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\gen\bootable_image\ivt_flashloader_signed.bin
toolStatus: 0
commandOutput: {
   "command" : "write-file",
   "response" : [ 3351091 ],
   "status" : {
      "value" : 305411090
自动生成的bd文件如下
options {
    flags = 0x08;
    startAddress = 0x20208200;
    ivtOffset = 0x0;
    initialLoadSize = 0x200;
    entryPointAddress = 0x2021b26d;
sources {
    elfFile = extern(0);
constants {
    SEC_CSF_HEADER              = 20;
    SEC_CSF_INSTALL_SRK         = 21;
    SEC_CSF_INSTALL_CSFK        = 22;
    SEC_CSF_INSTALL_NOCAK       = 23;
    SEC_CSF_AUTHENTICATE_CSF    = 24;
    SEC_CSF_INSTALL_KEY         = 25;
    SEC_CSF_AUTHENTICATE_DATA   = 26;
    SEC_CSF_INSTALL_SECRET_KEY  = 27;
    SEC_CSF_DECRYPT_DATA        = 28;
    SEC_NOP                     = 29;
    SEC_SET_MID                 = 30;
    SEC_SET_ENGINE              = 31;
    SEC_INIT                    = 32;
    SEC_UNLOCK                  = 33;
section (SEC_CSF_HEADER;
    Header_Version="4.2",
    Header_HashAlgorithm="sha256",
    Header_Engine="DCP",
    Header_EngineConfiguration=0,
    Header_CertificateFormat="x509",
    Header_SignatureFormat="CMS"
section (SEC_CSF_INSTALL_SRK;
    InstallSRK_Table="../../../gen/hab_cert/SRK_1_2_3_4_table.bin",
    InstallSRK_SourceIndex=0
section (SEC_CSF_INSTALL_CSFK;
    InstallCSFK_File="../../cst/crts/CSF1_1_sha256_2048_65537_v3_usr_crt.pem",
    InstallCSFK_CertificateFormat="x509"
section (SEC_CSF_AUTHENTICATE_CSF)
section (SEC_CSF_INSTALL_KEY;
    InstallKey_File="../../cst/crts/IMG1_1_sha256_2048_65537_v3_usr_crt.pem",
    InstallKey_VerificationIndex=0,
    InstallKey_TargetIndex=2)
section (SEC_CSF_AUTHENTICATE_DATA;
    AuthenticateData_VerificationIndex=2,
    AuthenticateData_Engine="DCP",
    AuthenticateData_EngineConfiguration=0)
section (SEC_SET_ENGINE;
    SetEngine_HashAlgorithm = "sha256",
    SetEngine_Engine = "DCP",
    SetEngine_EngineConfiguration = "0")
section (SEC_UNLOCK;
    Unlock_Engine = "SNVS",
    Unlock_features = "ZMK WRITE"
nxp-mcu bootutility报错截图如下:
但实际上,按键配置的是BMOD[1:0]=2'b01(serial downloader)
比较多的时候,启动模式会识别成BMOD[1:0]=2'b00(boot from fuse)
很少时候会是BMOD[1:0]=2'b10(internal boot)
然后识别到的UUID看起来也是不正常的
非常奇怪,从来不会把启动模式识别为BMOD[1:0]=2'b01(serial downloader)
ps:换成没有配置HAB的核心板,每次都能正常识别为BMOD[1:0]=2'b01(serial downloader)
3 返答(返信)
1,653件の閲覧回数
jay_heng
控制台命令截图不太完整,write-file 后面没有命令了吗?
1,565件の閲覧回数
Evanee
能不能再帮忙看一下,是什么原因?
1,643件の閲覧回数
Evanee
控制台完整截图以及内容如下:
toolStatus: 0
commandOutput: {
   "status" : {
      "value" : 305411090
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
toolStatus: 0
commandOutput: {
   "response" : [],
   "status" : {
      "value" : 305411090
        Section: 0x14
        Section: 0x15
        Section: 0x16
        Section: 0x18
        Section: 0x19
        Section: 0x1a
        Section: 0x1f
        Section: 0x21
toolStatus: 0
commandOutput: {
   "response" : [ 2290649224 ],
   "status" : {
      "value" : 305411090
Executing: D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\sdphost\win\sdphost -t 50000 -p COM22,115200 -j -- jump-address 539001344
toolStatus: 0
commandOutput: {
   "command" : "jump-address",
   "response" : [],
   "status" : {
      "value" : 305411090
Executing: D:\AEMBED\rt1052\soft\NXP-MCUBootUtility-master\tools\blhost2_3\win\blhost -t 50000 -p COM22,115200 -j -- get-property 1 0
toolStatus: 1
commandOutput: {
   "command" : "ping",
   "response" : [],
   "status" : {
      "description" : "10501 (0x2905) Invalid packet type.",
      "value" : 10501
toolStatus: 1
commandOutput: {
   "command" : "ping",
   "response" : [],
   "status" : {
      "value" : 10501
toolStatus: 1
commandOutput: {
   "command" : "ping",
   "response" : [],
   "status" : {
      "value" : 10501
toolStatus: 1
commandOutput: {
   "command" : "ping",
   "response" : [],
   "status" : {
      "value" : 10501
toolStatus: 1
commandOutput: {
   "command" : "ping",
   "response" : [],
   "status" : {
      "value" : 10501
