imx Rt595 I3C interface
697 次查看
gilmotta2
Hello All,
Can anyone please share or point an I3C sample code for the RT595 to me? I would like to run a test sending bytes over I3C. I'm using the MIMXRT595-EVK and I did not find any sample code for this EVK.
Gil
#RT595
686 次查看
jeremyzhou
Hi @gilmotta2 ,
To provide the fastest support, I'd like to refer to the I3C demo in the SDK for RT 595.
TIC
- We are following threads for 7 weeks after the
667 次查看
Mahesh_Chandra
SDK has two projects. One project is set up for I3C master and the other project is set up for I3C slave.
You can directly use these projects after connecting two MIMXRT595-EVK boards together as mentioned
in the code examples.
687 次查看
jeremyzhou
Hi @gilmotta2 ,
TIC
