iMX RT-1064 receive CAN FD Frames on CAN3
988 次查看
steffenrose
in CAN-FD mode the RX-Fifo should not be used.
What is the best way to receive a lot of CAN-FD Frames. More than one message object would be great for a burst of frames. Of course the frames should be read in the right order.
Thank you.
Steffen
标记 (2)
4 回复数
889 次查看
steffenrose
What is the correct value for MCR[MAXMB], if allmessages are CAN FD with 64Byte payload?
961 次查看
vicentegomez
you can check the table
Table 45-18. Maximum CAN bit rate in data phase on CAN FD frames
to check the best configuration for your application
930 次查看
steffenrose
I need a bittiming clock of 40MHz or 80Mhz (CiA1301 CANopen FD). I cannot see so much possible settings in the ConfigTool of the MCUXpresso.
The table 45-25 write, the max. MB count is 7.
Can I use the 40Mhz? Table 45-18 is unclear for me. I don't know, if I have to calculate with 7 MB or with a lot of RAM and a calculate number of e.g. 64.
What is the value for MCR[MAXMB]? 6?
Thank you.
Steffen
标记 (2)
856 次查看
steffenrose
@vicentegomezDo you have any clarification about the right interpretation of the table?
Thank you
Steffen
