I confirmed this thread.
https://community.nxp.com/t5/i-MX-RT/i-MX-RT-1064-Power-up/m-p/1198664
My application uses RT1170 without battery & sleep mode.
Can RT1170 also ignore power up sequence like RT1064?
Is it no problem to turn on/off all power rail(SNVS_IN, NVCC_XX, etc.) at the same timing?
解決済! 解決策の投稿を見る。
Hello, sorry for the late response I suggest reviewing the Hardware development guide.
Pavel
Hello, my name is Pavel, and I will be supporting your case, let me get into your case and when I have more information, I will contact you.
Pavel
