i.MX RT1170 - EDMA source address decrement
696 次查看
theoz
Good morning,
I'm using MIMXRT1170-EVK board and i want to know if there are the possibility to set the EDMA with a decrescent source address.
So, if i set for example source address at 0x1000 at every DMA trasfert the address decrease (0xFFC,0xFF8...). and not increse.
If there is this functionality, is possible applicate to a LSPI_EDMA transfer?
Thank a lot
685 次查看
jingpan
Hi @theoz ,
Yes, TCDx_SOFF register is sign-extended. If it has a negative number, the source address will decrease. It can  applicate to a LSPI_EDMA transfer.
Jing
670 次查看
theoz
Hi Jing,
thanks a lot.
Matteo
686 次查看
jingpan
Hi @theoz ,
Jing
