I would please like to ask about hyperFlash example (evkmimxrt1050_flexspi_hyper_flash_polling_transfer):
In the example, I see the following parts:
1. hyperFlash initialization
2. hyperFlash write of page
3. hyperFlash read of page
4. compare the read and write contents.
I had assumed that flexSPI interface only needs to be initialized (There is LUT for read and write command) , and then can be accessed by direct read/write from the absolute address (where the device is mapped to).
Yet, I see that the write functionality is done through wrappers:
flexspi_nor_flash_page_program -> FLEXSPI_TransferBlocking -> FLEXSPI_WriteBlocking
The read is done by direct access to address, is expected.
Can someone explain why the write must use this wrappers ?
Thank you,
ranran
已解决! 转到解答。
Hi ranran
since writing procedure requires some time for performing flashing
sequence, it waits (using blockng wrapper) until hyperflash will be ready for
next usage.
Hi ranran
next usage.
