debug console is not working, after following Boot to SDRAM procedure
456件の閲覧回数
ByoungogCho
I am working on IMX RT1020EVK board.   To boot  image to SDRAM,  I  followed the step of case 2. Add DCD by MCUxpresso IDE. (boot to Sdram.pdf)
made s19. file, and downloaded  s19 file through  MCU Boot utility 3.24.0 tool
but I cannot look at the message  of debug console...   ,   but I can find  the message, After downloading and booting  axf image file in XIP mode
What is the problem ??
I used  example iled_blinky from SDK.
#include "fsl_debug_console.h"    //-1
int main(void)
    /* Board pin init */
    BOARD_ConfigMPU();
    BOARD_InitBootPins();
    BOARD_InitBootClocks();
    BOARD_InitDebugConsole();   //-2
    /* Set systick reload value to generate 1ms interrupt */
    if (SysTick_Config(SystemCoreClock / 1000U))
        while (1)
DbgConsole_Printf("\r\nThis project S19 file create SDRAM boot testing \r\n");    // -3
    while (1)
        /* Delay 1000 ms */
        SysTick_DelayTicks(300U);
~~~~~   //Just 3 line is added on SDK example.
433件の閲覧回数
jingpan
Hi @ByoungogCho ,
I made a demo base in hello_world example. If you use MCUBootUtility to download the s19 following the guide, it can print "hello world SDRAM"
Jing
434件の閲覧回数
jingpan
Hi @ByoungogCho ,
Jing
