Simple question... what does the acronym "PODF" stand for? Nowhere in the RT1050 reference manual is it explained. Google indicates that NXP also uses this acronym with its i.MX 7 parts, but couldn't locate an explanation of the acronym. I mean, it's clearly a selector for a clock divider; based on context, maybe it's Post Divider... Fraction? It sometimes appears next to "PRED", which I'm guessing is "Pre-Divider". You did at least explain Phase Fractional Divider (PFD) in the reference manual, but nowhere can I find what "PODF" actually stands for. Thanks.
Solved! Go to Solution.
The PODF means the Post-Divider Fraction.
Hope this is clear.
TIC
Hope this is clear.
TIC
