What are the FlexSPI Configuration Block time units?
imxrtuser
Senior Contributor I
The recommended csHoldTime value is 0x03 (RT1020 Reference Manual). But what does a value of 0x03 mean? ist it 3 ns? The waitTimeCfgCommands is specified in 100 us. Is it the same for csHoldTime?
Our used flash specifies CS# Setup and Hold Time of 4 ns. What do I have to set csHoldTime to?
Kind regards,
Stefan
kerryzhou
Hi Stefan Mitterhauser,
  It is determined by your flexSPI serial root clock, please check the RT1020 reference manual
More details, please check the reference manual Chapter 26 FlexSPI Controller.
waitTimeCfgCommands is different, the unit is 100us.
If you want to set your CS# Setup and Hold Time of 4 ns, you can use your flexSPI serial root clock calculate the specific cycles which you need.
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
kerryzhou
Wish it helps you!
Kerry
imxrtuser
Hello Kerry,
thank you for your answer!
