Unable to run the application with image header using custom bootloader in IMX RT1170
130件の閲覧回数
Ragnar
Hi NXP,
          I'm trying to develop a custom bootloader for my board and when I try to jump to the application. I was unable to reconfigure the device from the application using image_header.
1. When it try to run the application without image_header. I was able to jump to the application and run it with the existing bootloader device configuration. But it is only limited and if I load the different bin file other than existing with different configurations it is getting failed.
2.When I try to run the application with the image_header. It is jumping but stucking at the start itself.
I am using RT1170EVK
My boot loader starts at 0x30000000 and ends at 0x30010000
Application starts from 0x30010000 ends at 0x31000000
So, can you please help me with this problem.
Ragnar.
2 返答(返信)
109件の閲覧回数
Habib_MS
Hello @Ragnar ,
In order to support you better can you provide me the next information?
-where will be loaded your image? (RAM or FLASH)
-Is the image_header the header of the IVT?
-Are you using Serial downloader or internal boot?
Also, this post could be help you with your inquiry: i.MX RT FLEXSPI booting guide - NXP Community
Habib.
56件の閲覧回数
Ragnar
Hi @Habib_MS ,
           Thanks for the response. I found that the problem is with my flash loading function as it's not erasing some sectors as a result it is overwriting to the existing data. So the flash data is getting corrupted and I was unable to run the application. Now it got resolved and thank for providing the reference it helped me a lot.
Ragnar.
