My application required timer interrupts, I had found
1)PIT
2)GPT
when I use GPT timers for example GPIO toggling, I'm not able to flash another hex code. Showing error CPU can't halt.
Is there any other timers to use in RT1176.
Thanks & Regards,
Manikanta Robbi.
Thank you so much for your interest in our products and for using our community.
For timer interrupts you can also the eFlexPWM and TMR modules.
Hope it helps you.
Have a nice day!
