Hi @5angxr ,
LPSPI contains both the MOSI and MISO, so even you send the data, you also can receive the data.
I think you may using the polling code.
If you want to do the receive anytime, you also can use the interrupt method.
More details, you totally can refer to our SDK code:
SDK_2_11_1_EVK-MIMXRT1060\boards\evkmimxrt1060\driver_examples\lpspi\interrupt_b2b
Wish it helps you!
kerry
