SRC_BOOT pin assigment conflict
1,004件の閲覧回数
masa3176
SRC_BOOT pin and TRACE[3:0] conflict in RT1171 PIN assignment. I don't understand how to use it, is it possible to switch this port in the emulator to make it work?
6 返答(返信)
996件の閲覧回数
kerryzhou
Hi @masa3176 ,
   You want to use SRC_BOOT pin and TRACE[3:0]  as other function, right?
  1. To SRC_BOOT pin
       You can configure it as your app required pin after boot.
       But, you need to make sure, during boot, the pin status maches the boot situation. Or you use boot from fuse, use the fuse to configure the boot_cfg.
2. About the TRACE[3:0]
  You also can use it as other function, just it will influence the Trace function.
  If you don't use the trace function, you totally can use your app function.
Wish it helps you!
Kerry
903件の閲覧回数
masa3176
Thank you for the adovice. I will confirm your advice.
987件の閲覧回数
masa3176
Hello
Thanks for your advice. SRC_BOOT also conflicts with LPSPI3. In this case as well, is it okay to think about what you said?
Thank you
972件の閲覧回数
kerryzhou
Hi @masa3176 ,
  It's the same situation, just make sure during the reset, the chip BOOT_CFG related pins matchs the boot, after boot succesfully, then you can use the app configure it to other function.
Wish it helps you!
Kerry
928件の閲覧回数
masa3176
Thank you
924件の閲覧回数
kerryzhou
You are welcome!
If your question is solved, please help to mark the correct answer, just to close this case.
Any new questions, welcome to create the new questions post, thanks.
Kerry
