Dear fangfang, kerryzhou and friends,
Thank you for your answer in the previous post.. The IS25WP064 driver did not meet our need. In the compatible memory table there are the partnumbers below. Are there any drivers for these memories to work with the RT1051?
Thank you very much for your attention!
Solved! Go to Solution.
Hello Rubens Junior ,
Thereare not the drivers for the QSPI part numbers list. Sorry for the inconvenience may cause.
TIC
TIC
