[RT1172] About AN13725 Doc
886件の閲覧回数
kayakaantuna
I want to run opencv on cortex-m7 mcu. When I check the forum about the topic, I found that AN13725 is the application note that I'm looking for. However, when I try to download it from NXP's own page it gives me the "Page Not Found (404)" error.
- So my first question is where can I find, AN13725 documentation and its attached software ?
I also do some research and found out the related doc in third-party site however, when I try to execute make using mingw32 (like the documentation suggest), I get the following errors:
Error running link command: The parameter is incorrect
3rdparty\zlib\CMakeFiles\zlib.dir\build.make:457: recipe for target '3rdparty/lib/libzlib.a' failed
mingw32-make[2]: *** [3rdparty/lib/libzlib.a] Error 2
CMakeFiles\Makefile2:185: recipe for target '3rdparty/zlib/CMakeFiles/zlib.dir/all' failed
mingw32-make[1]: *** [3rdparty/zlib/CMakeFiles/zlib.dir/all] Error 2
mingw32-make[1]: *** Waiting for unfinished jobs....
3rdparty\openjpeg\openjp2\CMakeFiles\libopenjp2.dir\build.make:613: recipe for target '3rdparty/lib/liblibopenjp2.a' failed
mingw32-make[2]: *** [3rdparty/lib/liblibopenjp2.a] Error 2
CMakeFiles\Makefile2:258: recipe for target '3rdparty/openjpeg/openjp2/CMakeFiles/libopenjp2.dir/all' failed
mingw32-make[1]: *** [3rdparty/openjpeg/openjp2/CMakeFiles/libopenjp2.dir/all] Error 2
Makefile:161: recipe for target 'all' failed
mingw32-make: *** [all] Error 2
I apperciate any answer, or suggestions.
Thanks.
9 返答(返信)
845件の閲覧回数
Kan_Li
Hi @kayakaantuna ,
There might be some web issue with AN13725, and our web team has been notified with this issue, which should be resolved soon. Thanks for your patience!
Kan
835件の閲覧回数
kayakaantuna
Thank you for your attention...
Can you inform me on here when it's fixed?
828件の閲覧回数
Kan_Li
Sure!
724件の閲覧回数
kayakaantuna
Hi @Kan_Li,
Any update regarding the SW package ?
785件の閲覧回数
kayakaantuna
Hi @Kan_Li,
It seems that your team did indeed upload the AN13725 documentation. Thanks for that!
However there is one small issue:
As you can see on the image above, there is a MCUXpresso project which must be attach to the AN13725 documentation. But I couldn't find any attach files...
Can you please also tell documentation team to upload this file ?
Thanks.
699件の閲覧回数
Kan_Li
Hi @kayakaantuna ,
The SW package can not be shared due to some release issue, but I have a keil project to work with opencv, please kindly refer to the attachment for details.
Kan
692件の閲覧回数
kayakaantuna
Hi @Kan_Li,
I imported your keil project to MCUXpresso however when the debugger passes this line:
	Mat img(Size(480, 360), CV_8UC3);// = cv::imread(path_name);
The JTAG just closes with the following log on console:
[Closed Telnet Session]
What may be the reason of this ? Memory or something ?
Also here is the full MCUXpresso project I'm working with, I included in the attachment
EDIT: Little update when I changed library to Newlib(semihost), I got the following log on the console:
SEGGER J-Link GDB Server V7.70d - Terminal output channel
hello world.
ld.
terminate called after throwing an instance of ' of 'cv::Exceptionption'
what(): (): OpenCV(4.8.0-dev) C:\RT1170_OPENCV\opencv\modules\core\src\alloc.cpp:73: error: (-4:Insufficient memory) Failed to allocate 518400 bytes in function 'OutOfMemoryError'
ror'
What am I doing wrong ?
Thanks.
668件の閲覧回数
Kan_Li
Seems the heap is not enough for your application, please adjust the heap size in MCUXpresso->Settings->MCU Linker.
Kan
658件の閲覧回数
kayakaantuna
Hi @Kan_Li,
My heap settings as follows:
And memory configuration as follows:
So on SDRAM, it looks to me that I have enough memory for Mat variable.
Am I doing something wrong in somewhere ? Can you guide me ?
Thanks.
