RT1170 Compatible Camera Modules
344件の閲覧回数
christinad
Since the RT1170 processors don't support RAW data and YUV422(10 bit) formats on the MIPI CSI block, do you have camera modules you recommend that will be compatible with the processor? Ideally it would be global shutter.
Thanks!
327件の閲覧回数
EdwinHz
Hi @christinad,
I recommend you take a look to the Smart HMI solution based on the RT1170: NXP EdgeReady Smart HMI Solution Based on i.MX RT117H with ML Vision, Voice and Graphical UI | NXP S.... This is a great reference point for HMI applications using the RT1170, like what RGB or IR camera to use and how to interface it. In this case, you can take a look to the camera's P/N on the SLN-TLHMI-IOT Hardware Design Files.
BR,
Edwin.
