Hi all
I want to try HAB signed Image Boot
I followed JayHeng's Blog but something got wrong
Can anyone help me ?
Thanks!
Andy Dong
Hi Andy Dong ,
1. Please download the newest MCUBootUtility tool from this link:
https://github.com/JayHeng/NXP-MCUBootUtility/releases/tag/v2.0.0
2. Please try the unsigned mode to download the code instead of the HAB signed boot mode
You can use the tool's image directly.
Just to download the code again, do you still meet the .py problem?
Please try it at first.
If the unsigned mode is working, then you can try the HAB mode again.
Any updated information from you side, please kindly let me know.
Kerry
Hi, Kerry Zhou
It's worked when I used the image from NXP-MCUBootUtility-2.0.0 \ apps \ NXP_MIMXRT1050-EVKB_Rev.A \
But I used the .axf from MCUXpresso 's example ( I don't edit anything ) , it's not worked.
Just like the below picture
And I also try to use .s19 generated by MCUXpresso then it's worked.
I try both .s19 and tool's image with HAB signed image Boot
The result is same as version 1.4.0
Andy Dongag
Hi Andy Dongag,
Thank you for your updated information.
Today, I have test it on my side, it works OK when I select the HAB signed image boot.
This is my test result log:
When you use the HAB signed image boot, you need to follow this post:
痞子衡嵌入式:开启NXP-MCUBootUtility工具的HAB签名功能 - CST(中英双语) - 痞子衡 - 博客园
You need to modify hab4_pki_tree.bat in the folder: NXP-MCUBootUtility-2.0.0\tools\cst\keys
Do you modify it? And download the cst tool, and copy it to the MCUbootutility?
Please also note, you need to use the win10 system, do you also use the correct PC system?
Kerry
Hi, Kerry Zhou
I found that my setting with hab4_pki_tree.bat got wrong.
Now, I can use HAB signed image boot
Then, I followed the post to activate HAB Encrypted Boot
痞子衡嵌入式:开启NXP-MCUBootUtility工具的HAB加密功能 - CST(中英双语)
openssl version : openssl-1.0.2r
When I click "Connect to ROM" ,it got error.
Is there any suggestions ? Thanks!!
Andy Dong
Hi Andy Dong,
Sorry for my later reply.
I test the whole encryption function these days, really caused me a lot of time, because I also meet some problems.
But, after I check your problem again, your problem still in the connection side.
You can disconnect your board, then close the MCUBootUtility tool, open it again, power off you board, let it in the serial download mode, then try to connect it again. Please make sure your MCUBootUtility configure the correct external memory. You also can try the UART connection, your problem should still not related to the encryption.
Please try the connection more times.
I don't have the connection problems, and I also can download the HAB encrypted image boot code to the external flash, please note, the image should be non-xip, with XIP image, will have problems.
Kerry
Hi Andy Dong,
Do you finished the
and
configuration?
Could you share all the MSYS2 MSYS and MSYS MinGW32-bit windows log?
I need to check it is correct.
Kerry
