Hello Team,
I would like to thank for your great support for the queries. I'm having doubts in following two questions,
1) How to do the block erase using ROM API?, it is taking quite long time for erase the flash memory before write the application image.
2) Please find the attached hex file, jump is not happening for this hex file, I've verified the written data, it has parsed the data and write it correctly into the memory, but jump is not happening for this file, kindly let me know the reason behind this problem?
Note: Jump is happening for SDK example projects.
