Issue running the ecompass_cm7 example SDK on the RT1170 EVK
LuisC
When trying to run the ecompass SDK example to test the functionality with the FXOS8700CQ sensor, this message is received in the serial terminal: "Sensor device initialize failed!".
DanielRuvalcaba
Could you please show me a picture/diagram of your setup connections?
Best regards, Daniel.
