I am using MIMXRT1050 evaluation board. I need to use a custom display. So does this board support 4 inch display?
Thank you.Looking for the solution to the query.
Kaveri
Dear @KaveriA
Thanks a lot for reaching our technical support.
Regarding your question, the MIMXRT1050 EVK can support 24-bit parallel LCD (RGB), so the 4 inches display that you mention has to be compatible with this interface.
Hope that helps you, please let me know if you have some more questions.
Best Regards.
Pablo Avalos.
@PabloAvalos, Thanks for the response.
If the display supports 16 bit parallel RGB interface? Is the microcontroller compatible with the display ?
Thank you
Kaveri A
Dear @KaveriA
That's correct. It might be supported, but you have to consider pins compatibility too.
Best Regards.
Pablo Avalos.
