IMXRT1064 MCUXpresso SPT - Flash Programmer Tool - Recovery - EVK
660件の閲覧回数
Lukas_Frank
Senior Contributor I
Hi Dear Authorized,
I apply the recovery procedure to my EVK seen in Figure Set 1. Because I got below error. After apply recovery procedure I think that this error will be disappear. But it still continue. However, I tried to debug my EVK with different workspace it works correctly. I can't understand the issue. Why I can't debug my EVK with the workspace which I was able to debug successfully before. Do you have any idea?
Thanks and Regards.
Figure Set 1 : Applied Recovery Procedure with MCUXpresso SPT
Lukas_Frank_1-1692590380256.pngLukas_Frank_2-1692590389407.pngLukas_Frank_3-1692590415452.png
Lukas_Frank_4-1692590773781.pngLukas_Frank_5-1692590798468.pngLukas_Frank_6-1692590806743.png
589件の閲覧回数
Pavel_Hernandez
Hello, sorry for the late response, the curious behaviors were new for me, and then I noticed this.
    It seems that using a 1024 project on RT1064, which will cause a wrong, which means FCB, to be downloaded. Please help confirm that, and using the same project with the board:
Pavel
4 返答(返信)
590件の閲覧回数
Pavel_Hernandez
Pavel
559件の閲覧回数
Lukas_Frank
Hi Dear @Pavel_Hernandez ,
I tried too many combinations. After a while, I pass some steps spontaneusly.
Thank you soo much for your helps.
632件の閲覧回数
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, let me get into your case and when I have more information, I will contact you.
Pavel
618件の閲覧回数
Lukas_Frank
Thank you so much.
