IMXRT10** DCDC_OUT accuracy
895 次查看
gavin5342
I can't see the accuracy spec for the DCDC converter on IMXRT10**.  The reason for asking is that the datasheet specifies, for VDD_SOC min 1.15V for normal operation and 1.25V for overdrive.
I have seen some SDK examples set DCDC_OUT to 1.25V for overdrive configuration and others set DCDC_OUT to 1.275V for overdrive.
815 次查看
lucas_cao
1.275V is the correct voltage, the 1.25V setting in SDK code should be updated.
4 回复数
816 次查看
lucas_cao
810 次查看
gavin5342
Thanks very much! That makes most sense to me too.
817 次查看
gavin5342
I am interested in the answer for RT1050 series and RT1010 series.  For both of these devices the range is 1.15 - 1.3V as you show here.
883 次查看
diego_charles
Hi @gavin5342
I hope you are doing great!
To give you a better response :  could you specify in which part number and related SDK did you saw those parameters and  DCDC output settings?
For example, according to the RT1060 DS, the VDD_SOC_IN tolerates up to 1.3v
All the best,
Diego
