How to re-enumerate a USB device
1,027件の閲覧回数
iscylinfromtw
I'm using the USB host of RT1060. Actually, I'm not familiar with USB host behavior. When data communication occurred error, I try to set the port reset bit of USB_nPORTSC1 register to re-enumerate the USB device again. From the USB packet sniffer (as attachment), the USB host controller sending the J-state packet but does not issue any Get_Descriptor command. Does any step I miss during the process?
1,003件の閲覧回数
FelipeGarcia
Maybe you can try using USB_HostCdcDeinit API from the SDK.
Felipe
