Hi, all,
I'm working with i.MX RT1050 Evaluation Kit.
How should I configure and build the project binary compatible with SD card using MCUXpresso IDE?
Thank you in advance.
解決済! 解決策の投稿を見る。
o provide the fastest possible support, I'd highly recommend you to refer to the post.
TIC
TIC
Thank you!
I works for me in both debugging and flashing for iled_blinky demo;
however, for flash component nor it works only after flashing - debug crashes? - don't understand why.
