We've used RT1052 on our device.
and We're planning to add PN7150 for contactless payment system on it.
I wonder if that chipset combination is no problem for working as payment system.
Or Shoule we use KL81 MCU + PN7150 for contactless payment system?
Thank you,
Andy
Solved! Go to Solution.
Hi Andy,
Thanks for your reply.
1) Do you think RT1050 has a security risk when using it for a contactless payment solution?
-- Yes.
TIC
1) Shoule we use KL81 MCU + PN7150 for contactless payment system?
-- Benefit from the rich security features, I consider the KL81 is better choice than the RT1052.
TIC
Hi, Jeremyzhou
Thanks for your prompt reply and comments.
Actually, we just use NFC technology for contactless payment.
As far as I know, K81/KL81 is a solution for POS teminal which supports contact card, contactless card and magstripe card for payment.
Do you think RT1050 have a security risk when using it for contactless payment solution?
Thank you
Andy
Hi Andy,
-- Yes.
TIC
Hi, Jeremyzhou,
Let me close this case
Thank you,
Andy
