In Q&A , from https://community.nxp.com/t5/LPC-Microcontrollers/What-s-the-easiest-way-to-execute-a-reset/td-p/801... , now I found NVIC_SystemReset() is usable. but,
For get the reson of reset, I want to use some register
In case of AVR., I did this like below
void reset_action(int code) // the code is reason type, or path of reset
volatile avr32_pm_t *pm = &AVR32_PM; // this is one of AVR power management registers
// reboot reason value save
pm->gplp[0] = code;
//Reset_mcu
wdt_reset_mcu();
Please Let me know good ways to keep the data ,after SW reset with data value
(not file log..it is big load)
anyway,. I tried to use reserved region of AIRCR[14:3], but already AIRCR[14:8] is used (priority group ??) , so AIRCR[7:3] but It is cleared after Reset.
Solved! Go to Solution.
Hi @Seongyon_Jeong ,
Thanks for your trust!
Next time, please use your company email to create the question, then your question will have higher support priority, don't use the 3rd part email to create the question, thanks.
If your question is solved, please help to mark the correct answer, just to close this case.
Any new issues, welcome to use the company email to create the new case.
Kerry
