Bricked RT 1020 board?
bp1979
Senior Contributor I
I am using an RT 1020 EVK board. While trying to resolve an issue related to SRAM_DTC size, I uploaded the suggested configuration. Afterwards I was no longer able to upload anything new.
I had a similar issue before, then I was able to recover following the "troubleshooting" steps in this guide. But even these steps no longer revive my board.
When I normally upload to my board using the debug icon in Xpresso, I get this error:
0 SWD devices detected.
How do I recover from this problem?
bp1979
Problem solved. Took me long enough, but in the end this was the solution:
- power off board
- Set boot dip switches to 1-1-1-0
- Go to MCU Xpresso
- Generate a new project with the wizard (next next finish)
- Compile it (to generate a .axf executable)
- Press the flash icon
In the first dialog, I deselected all probes except CMSIS DAP.
In the second dialog, I changed nothing. The .axf was default selected.
- Press the "Run.." button, and let it upload.
- Power off board again
- Change back the dipswitches to 1-0-1-0
- Upload your program with debug button, and I was back online.
Hope this will help anybody who's struggling with this too.
bp1979
- power off board
- Go to MCU Xpresso
