About i.MX RT1050 FlexRAM Allocation
2,473件の閲覧回数
ogawatakeshi
Hello !
I'm using MCUXpresso with MIMXRT1050-EVK(SDK Version : 2.3.0)
I have a two questions.
First,are ram allocation sample is available?
It is not on the list in my environment(but it exists in the folder)
It has not been added to manifest xml files.
The second is about FlexRAM  registers.
FlexRAM ram allocation sample  uses magic number register.
but It is not shown in the reference manual.
and the part of the magic number match flag is also reserved.
Are the above problems fixed?
ラベル(2)
タグ(1)
1,988件の閲覧回数
Yuri
  Customers can look at fsl_flexram.c file in the SDK.
Yuri.
3 返答(返信)
1,988件の閲覧回数
Yuri
  The FlexRAM is configurable. Refer to GPR16 General Purpose Register
(IOMUXC_GPR_GPR16) and GPR17 General Purpose Register (IOMUXC_GPR_GPR17).
  Also, the following may be helpful.
"Using the i.MX RT FlexRAM"
https://www.nxp.com/docs/en/application-note/AN12077.pdf
Overview of using the MIMXRT1050-EVK with MCUXpresso IDE
Yuri
1,988件の閲覧回数
ogawatakeshi
Thanks for Replying
I try to set (IOMUXC_GPR_GPR16) and GPR17 General Purpose Register, but debug is fault
I tried with the following code
#define IOMUXC_GPR_GPR17_ADDR 0x400AC044
#define IOMUXC_GPR_GPR16_ADDR 0x400AC040
SCB_DisableICache();
SCB_DisableDCache();
volatile unsigned int *b = ((unsigned int *)IOMUXC_GPR_GPR17_ADDR);
*b = 0b01011010111111111111111110100101;
volatile unsigned int *a = ((unsigned int *)IOMUXC_GPR_GPR16_ADDR);
*a |= 1<<2;
And,It is helpful to have sample code about this case in the manual
I need some advice .
thanks
1,989件の閲覧回数
Yuri
Yuri.
