1160+1ZM and BT SPP profile
1,603件の閲覧回数
kostya740
Hello, I need your help.
I have MIMXRT1160-EVK witn 1ZM M2 WIFI-BT module.
I was import edgefast_bluetooth/spp example from 2.13 SDK.
Modified define to WIFI_88W8987_BOARD_MURATA_1ZM_M2 in a app_config.h
Build finished it without any errors.
Flashed without any errors.
But it is not working. In a terminal, I see only part of output "[sdio] E"
At pin SDIO_CLK I see 400kHz frequency, about 200ms from board start only.
Help me please with this example.
タグ(4)
11 返答(返信)
1,517件の閲覧回数
kostya740
Hi @DanielRuvalcaba
It is issue when try wifi_cli example. Could you please help?
1,502件の閲覧回数
DanielRuvalcaba
I’m taking a look into this.
Let me get back to you when I get an update.
Daniel.
1,482件の閲覧回数
kostya740
Hi @DanielRuvalcaba
I checked a few points.
1. Is it ok about 400kHz frequency?
2. I have next oscillograms after power on half second.
SDIO CLK
SDIO CMD
3.
1,413件の閲覧回数
kostya740
@DanielRuvalcaba Hi, doesn't you have any idea?
1,268件の閲覧回数
DanielRuvalcaba
Hi @kostya740,
I'm sorry for the late reply.
Could you please tell me if you have removed R183 and added 0ohm resistor at R404 on your board?
Daniel.
1,245件の閲覧回数
kostya740
yes, off course.
1,222件の閲覧回数
DanielRuvalcaba
Hi @kostya740,
Could you please send me a picture of your whole setup?
Daniel.
877件の閲覧回数
DanielRuvalcaba
Hi @kostya740,
By any chance were you able to get the picture of your whole setup?
Daniel.
1,367件の閲覧回数
nxf77486
We are still working on your case, we apologize in advance for the time this will take.
As soon as we have some feedback I would let you know.
1,580件の閲覧回数
DanielRuvalcaba
Hi @kostya740,
Could you please help me with the following information?
  • Are you using external power?
  • Are you able to run a Wi-Fi example?
  • Did you do the hardware rework as stated in the Hardware Rework Guide for EdgeFast Bluetooth Protocol Abstraction Layer?
Daniel.
1,568件の閲覧回数
kostya740
Hi@DanielRuvalcaba
Thank you for help.
1. Yes. External.
2. I tried. Didn't work too.
3. No. I will do all the need. Thanks.
Do you have another idea? Why didn't BT/WIFI examples work?
