Hello, I need your help.
I have MIMXRT1160-EVK witn 1ZM M2 WIFI-BT module.
I was import edgefast_bluetooth/spp example from 2.13 SDK.
Modified define to WIFI_88W8987_BOARD_MURATA_1ZM_M2 in a app_config.h
Build finished it without any errors.
Flashed without any errors.
But it is not working. In a terminal, I see only part of output "[sdio] E"
At pin SDIO_CLK I see 400kHz frequency, about 200ms from board start only.
Help me please with this example.
I’m taking a look into this.
Let me get back to you when I get an update.
Daniel.
Hi @kostya740,
I'm sorry for the late reply.
Could you please tell me if you have removed R183 and added 0ohm resistor at R404 on your board?
Daniel.
Hi @kostya740,
Could you please help me with the following information?
Daniel.
