u-boot pad setting customization
704件の閲覧回数
nikhil_sahu2
I am using some pad setting at the time of u-boot. just like below
=> mw 020E0158 3
=> saveenv
Saving Environment to MMC... Writing to MMC(2)... OK
this thing i have to write everytime the board boot, i want to thease changes in my u-boot source code.
Guys anyone can give me some idea where and how i can add this command u-boot source code in a proper way so i do not need to add this manually everytime. and this runs automatically.
Thanks in advance,
Nikhil
タグ(3)
676件の閲覧回数
AldoG
I could comment on 2 ways you may achieve this, there may be better options, you may try them and check if they serve for your purpose.
 - Modify device tree
You may add the pad setting for it to have the configuration you desire when uboot starts, I don't know which device you're working with, as reference imx8mm evk dts is here:
https://source.codeaurora.org/external/imx/uboot-imx/tree/arch/arm/dts/fsl-imx8mm-evk.dts?h=imx_v201...
- Modify config file
You may modify the .h file corresponding to the board you're working with and add your command there to run while booting, as a reference imx8mm evk config file is here:
https://source.codeaurora.org/external/imx/uboot-imx/tree/include/configs/imx8mm_evk.h?h=imx_v2019.0...
Hope this helps,
Aldo.
