I tried to build SPL for mx6sxsabresd, but the build fails. Below you can see the steps I did and the error message. Is this build target supposed to work and if so am I missing something?
$ make mx6sxsabresd_spl_defconfig $ make ... LD spl/u-boot-spl OBJCOPY spl/u-boot-spl-nodtb.bin COPY spl/u-boot-spl.bin CFG spl/u-boot-spl.cfg CFGS arch/arm/imx-common/spl_sd.cfg.cfgtmp MKIMAGE SPL Error: Image corrupt DCD size 536870911 exceed maximum 220 arch/arm/imx-common/Makefile:73: recipe for target 'SPL' failed make[1]: *** [SPL] Error 1 Makefile:963: recipe for target 'SPL' failed Thanks,
Solved! Go to Solution.
Hi Andreas
nxp uboot does not support spl, community uboot supports it
GitHub - Freescale/u-boot-fslc: U-Boot tree to host pending fixes and improvements
uboot spl issues can be posted on uboot mail list
Hi Andreas,
mx6sxsabresd_spl_defconfig target builds fine with mainline U-boot. Just get the latest one from git.denx.de Git - u-boot.git/summary and you will be able to build it.
Hi Fabio and thanks for the suggestion. I've tested with both mainline and community u-boot and I can confirm that they compile.
Hi Andreas
