tty/serial/imx.c miss operation when use tty set break
1,423件の閲覧回数
xiongweihuang
Hi all
On current git tree ,
In imx.c , when operate with tty .break_ctl
734 static void imx_break_ctl(struct uart_port *port, int break_state)
735 {
736         struct imx_port *sport = (struct imx_port *)port;
737         unsigned long flags, temp;
738
739         spin_lock_irqsave(&sport->port.lock, flags);
740
741         temp = readl(sport->port.membase + UCR1) & ~UCR1_SNDBRK;
742
743         if ( break_state != 0 )
744                 temp |= UCR1_SNDBRK;
You miss the revert back the register of UCR1_SNDBRK
This should be a bug , here is the patch . please check and approve
Original Attachment has been moved to: tty_imx_brk.patch.zip
ラベル(6)
676件の閲覧回数
fushi_peng
Your patch :
--- a/drivers/tty/serial/imx.c
+++ b/drivers/tty/serial/imx.c
@@ -739,6 +739,8 @@ static void imx_break_ctl(struct uart_port *port, int break_state)
+ else
+ temp &= ~UCR1_SNDBRK;
But from original  code :
Is that same as your change?
2 返答(返信)
676件の閲覧回数
YixingKong
Senior Contributor IV
Hi Xiongwei, is Fushi's reply help your question? If yes, please close the DI, oherwise please keep working with him.
Yixing
677件の閲覧回数
fushi_peng
Your patch :
+ else
