spread spectrum setting for i.MX6UL Linux BSP
1,198 次查看
yuuki
Senior Contributor II
Dear all,
We run LinuxBSP(L4.1.15) on i.MX6UL2(To.1.1)EVK board.
We want to use spread spectrum function in PLL2.
We found the following URL.
However, this is explanation for LTIB.
https://community.nxp.com/docs/DOC-100036
In YOCTO Linux BSP(L4.1.15), where is spectrum spread set?
Would you tell me a position and the file name of the source code?
May I have advice?
Yuuki
标签 (2)
标记 (4)
650 次查看
Yuri
The mentioned (previous) approach uses “file in uboot, named flash_headr.S,
which has the DDR initialization code which implement by DCD mode ; under DCD mode,
we can’t added the spread spectrum code, so we use another method called plugin, plugin will
allow to execute code before the DDR initialization”.
  For U-boot of Linux BSP L4.1.15, according to the Linux Porting Guide :
1. To port to the custom board, the DDR needs to be initialized properly.
2. Take a example for the i.MX 6Quad custom board. Open the file: board/freescale/
mx6<customer_board_name>/imximage.cfg to mx6q.cfg.
3. Modify all items in this file to match the memory specifications. These code blocks
are read by the ROM code to initialize your DDR memory.
  For more details about boot ROM plugin mode, please create request.
How to submit a new question for NXP Support
Yuri
651 次查看
Yuri
Yuri
