Dear Person in charge,
Now, we're developing our product based on i.MX 8M Mini (Linux on Cortex-A53 and RTOS on Cortex-M4) as bellow.
- MIPI-DSI ( display indication ) on Cortex-A53 side
- MIPI-CSI ( for camera data transfer) on Cortex-M4 side
And then, would you please let me know the setting procedure of function allocation on each cores.
- MIPI-CSI
- CSI-Bridge
- MIPI-DSI
best regards,
Shu
Hi Igor-san,
Thanks for your answer.
I understood.
best regarsd,
Shu
Hi 野田 周作
for allocating task for some core one can try to use CPU affinity, described on
How to run a program with only one CPU core? - Ask Ubuntu
As example one can refer to attached patch for L4.9.88_2.0.0
which assigns the GPIO banks irqs to CPU2 from probe time.
