[report] bsp imx-4.19.35_1.1.0 bug - fetch jailhouse failed
1,371 次查看
kunyichen
build failed fsl-image-validation-imx on imx-4.19.35_1.1.0 for imx8mmevk
change the below context will fixed the bugs, due to original src path only for intranet/nxp empolee
git diff
diff --git a/imx/meta-sdk/recipes-extended/jailhouse/jailhouse_0.10.bb b/imx/meta-sdk/recipes-extended/jailhouse/jailhouse_0.10.bb
index 2079718dc..fb4e376ec 100644
--- a/imx/meta-sdk/recipes-extended/jailhouse/jailhouse_0.10.bb
+++ b/imx/meta-sdk/recipes-extended/jailhouse/jailhouse_0.10.bb
@@ -1,7 +1,7 @@
 require jailhouse.inc
-SRCBRANCH = "imx_v0.10_y"
-IMX_JAILHOUSE_SRC ?= "git://source.codeaurora.org/external/imx/imx-jailhouse.git;protocol=ssh"
+SRCBRANCH = "imx_4.19.35_1.1.0"
+IMX_JAILHOUSE_SRC ?= "git://source.codeaurora.org/external/imx/imx-jailhouse.git;protocol=https"
1,166 次查看
gusarambula
Hello KunYi Chen,
The 4.19.35 kernel is not part of the BSP release, but you may collaborate to the Community BSP using the channels found on the link below:
https://freescale.github.io/#contributing
Thank you for reporting this bug!
1,166 次查看
kunyichen
gusarambula‌ thank you for your reply,
but the issues have been fixed on meta-fsl-bsp-release by Jun Zhu <junzhu@nxp.com>
meta-fsl-bsp-release - i.MX Yocto Project Release Layer
