qt5.4 wayland on imx6 crashes with segfault
1,150 次查看
h4nn35
when I try to start a qtquick application or the qtwebengine example browser, the application crashes with following output:
/usr/share/qt5/examples/webengine/quicknanobrowser# ./quicknanobrowser -platform wayland-egl
Using Wayland-EGL
Segmentation fault
A widget based application is working fine:
/usr/share/qt5/examples/widgets/widgets/calculator# ./calculator -platform wayland-egl
Using Wayland-EGL
I also tried chromium which is working fine and has full gpu support.
What do I miss? Or is there an showstopper?
I'm using Yocto fido (Qt5.4) and the freescale kernel imx_3.14.28_1.0.0_ga.
Hannes
标签 (4)
457 次查看
Bio_TICFSL
Hi Johannes,
This a bug from qt side, apparently is a context sharing issue with qtwebengine, hope to be solved soon.
[QTBUG-45122] webenginewidget examples do not render correctly on embedded platform - Qt Bug Tracker
457 次查看
h4nn35
thanks for your reply.
Do you know if these bugs were fixed in Qt5.5? Because I want to switch to Qt5.5 as soon as is available in yocto.
