mount ntfs on i.MX8MM
shengfazhang
Hi, I want to mount NTFS USB flash disk with the following command:
mount -t ntfs sda1 /tmp/udisk/
mount: /tmp/udisk: unknown filesystem type 'ntfs'.
How can I change the config to support NTFS on i.MX8MM.
Thanks!
b36401
You need to add NTFS filesystem support to your kernel. For example you can use ntfs3g driver.
b36401
