mangodb with imx93evk
317件の閲覧回数
ranga_yn
i want to run mango db server with docker io on imx93evk. let me know how can i do the same.
root@imx93evk:~# uname -a
Linux imx93evk 6.1.36+g04b05c5527e9 #1 SMP PREEMPT Mon Sep  4 21:11:15 UTC 2023 aarch64 GNU/Linux
We need to install docker utils and docker.io  on this IMX board .These docker needs to pull mongod from dockerhub. Is there any specific way please let me know as apt-get is failing
ranga
6 返答(返信)
279件の閲覧回数
ranga_yn
Hello team,
I flashed the SD card with  6.6.3 - default image
root@imx93evk:/etc/apt# cat /etc/os-release
ID=fsl-imx-xwayland
NAME="NXP i.MX Release Distro"
VERSION="6.6-nanbield (nanbield)"
VERSION_ID=6.6-nanbield
VERSION_CODENAME="nanbield"
PRETTY_NAME="NXP i.MX Release Distro 6.6-nanbield (nanbield)"
CPE_NAME="cpe:/o:openembedded:fsl-imx-xwayland:6.6-nanbield"
uname -a
Linux imx93evk 6.6.3-lts-next-gccf0a99701a7 #1 SMP PREEMPT Thu Feb 29 08:37:44 UTC 2024 aarch64 GNU/Linux
flashed by below steps:
sudo dd if=imx-image-full-imx93evk.wic of=/dev/mmcblk0 bs=1M && syncl
let me know how to proceed to have docker io on this board so that later - have the mangodb.
283件の閲覧回数
ranga_yn
Hello Community,
Thanks for the input as i wanted to flash on SD card let me know the maximum size SD supported and flashing on the SD card steps. which image i have to download from this default package [LF_v6.6.3-1.0.0_images_IMX93EVK].
or
imx-image-multimedia-imx93evk.wic
please let me know the steps.
270件の閲覧回数
Bio_TICFSL
You have to download the full-image to use docker and memory is 32GB
267件の閲覧回数
ranga_yn
Thanks for the input,
could you please let me know the next steps - Below is the board with flashed image now.
Last login: Thu Apr 25 10:23:31 2024 from 172.24.41.142
root@imx93evk:~# cat /etc/os-release
ID=fsl-imx-xwayland
root@imx93evk:~#
Does the default image support or i have to build the source - with recipe included.
ranga
288件の閲覧回数
Bio_TICFSL
If you are yocto you have to download using wget and the page of dockerhub, but the version 6.6.3 support docker you can download and install on your board from:
https://www.nxp.com/design/design-center/software/embedded-software/i-mx-software/embedded-linux-for...
160件の閲覧回数
ranga_yn
Hello NXP,
Thanks for the input. Currently i am building the imx93EVK source and added mongodb  as the below changes local.conf.
DISTRO_FEATURES:append = "mongodb"
but how to change the mongo db recipe to build with version -6.0.8 . An specific guide to change the current bb file to support this version on build time.
thanks,
