iMX93 - TPM in input capture mode
MoonLight1
I'm trying to configure one of the TPM modules to use one of the channels as an input capture mode.
When I select the tpm_ch on MCUXpresso, it shows as an output.
How can I set it as an input?
Thanks.
joanxie
did you use input_capture of tpm driver in the SDK? and let me remind, refer to the reference manual, TPM1_CH1, TPM1_CH3 are only supported as outputs, not inputs
