load per cpu
load per cpu
1,273 次查看
niklasmolin
Senior Contributor I
Hi.
I'm using Yocto to build my linux image for a i.MX6D (2 cores).
How do I check how much load is on each core.
When I run top, it only show the total load.
Is there a way to see how much load is on each core.
Niklas
标签 (3)
996 次查看
dmitrypozhidaev
try htop
it is more humane
5 回复数
997 次查看
dmitrypozhidaev
try htop
it is more humane
996 次查看
niklasmolin
I was considering to try this command, I haven't had any time to test it yet.
996 次查看
b36401
You can simply type "1" when you are running top utility
to see per core CPU load.
Victor
996 次查看
niklasmolin
Hi Victor.
I tried "1", but nothing happens.
Could it be that it only runs on one Core?
When I do a "more /proc/cpuInfo" I can see both cores.
Niklas
996 次查看
igorpadykov
Hi Niklas
I think links below answer this
Load (computing) - Wikipedia, the free encyclopedia
How do I Find Out Linux CPU Utilization? - nixCraft
chip
