linux interrupt time
993件の閲覧回数
2548903578
Hi,everyone
  When I use imx6sx to configure the interrupt, the external will trigger an interrupt every 20ms, but the interrupt is not entered immediately after the interrupt is triggered, and there will be a certain delay. This delay time is about 10us. The problem now is that it is okay if the delay is 10us each time, but I found that the time of each entry interrupt is not fixed, sometimes it is long and sometimes short. There will be a certain error in this way. Does anyone know how to solve this problem? We are expecting a reply.
5 返答(返信)
986件の閲覧回数
igorpadykov
973件の閲覧回数
2548903578
Hi,igorpadykov
 Real-Time Edge Software does not support imx6sx platform, only imx6ull.
969件の閲覧回数
igorpadykov
you can port it yourself using i.MX6ULL as example.
977件の閲覧回数
2548903578
Hi,igorpadykov
Can rt patches make the interruption time stable? I tested it and found that it is not as good as not adding it. We are using pin input interrupt, does fiq support it? Our m4 can only open one interrupt, so no other interrupts can be used.
991件の閲覧回数
2548903578
I played the rt package and still the same situation.
