Dear All
I'm trying to setup my iMX53 QSBoard for inflexion ui. While compiling the LTIB I run into a glib2 error.
Failed building glib2f_buildrpms() returned an error, exiting traceback: main:560Started: Sat Dec 5 03:19:36 2009Ended: Sat Dec 5 03:29:46 2009Elapsed: 610 secondsThese packages failed to build: glib2Build FailedExiting on error or interrupt
http://imxdev.org/wiki/index.php?title=ALL_Boards_ltib_config_ubuntu tells me to
install the libglib2.0-dev package. So I try:
sudo apt-get install libglib2.0-dev (which works)./ltib --pkg libglib2.0-dev
The latter command results in the system telling me it can not find this package and would like to see the spec file.
I'm quit new to this and google does not seem to give me a solution.
thx in advance
kind regards
Lyven
Thx for the reply, I solved it by reinstalling the libglib2.0-dev on my host linux. Afterwards I did a ./ltib -m distclean and recompiled. It worked after that.
Hi Lyven, there might be many reasons as well.
Check for the required dependencies and importantly, make sure you dont mess up with the glibraries...
Regards ::: Krishna Pavan
