This is fresh setup and first i tried u-boot setup using serial console. This required because board gets hang during boot.
After this i tried Timessys linux using mfgtools and this is giving kernel panic issue.
So the question is that which one is stable os for this board, (prefered one as per me is yokto).
Can any of you suggest us the steps here, as may be i am missing something which is causing this board with kernel panic issue.
KK
Hi jasnam,
Have you solved your problem now?
Best Regards
Dan
Hi KK,
I do not have any problem with yocto on this board... for inspiration look to the DaianeAngolini training Yocto Training - HOME
Jozef
As I know sabre lite and nitrogen is very well maintained in FSL Community BSP.
For sabrelite/nitrogen, please, double check your u-boot, as those boards does not boot from sdcard.
