imx8qm write u-boot to sd-card
571 次查看
Ahelion
Hello all,
I am following this guide: https://www.nxp.com/docs/en/user-guide/IMX_YOCTO_PROJECT_USERS_GUIDE.pdf
i am building the u-boot, but it does not say how to flash the u-boot once you have it.
Any ideea, here are the generated files?
Br,
标记 (1)
535 次查看
Harvey021
One should be like imx-boot-imx8qmmek-sd.bin-flash
Harvey
541 次查看
Harvey021
You'll find from uuu_1.5.177 about how to flash u-boot from uuu.pdf
Harvey
537 次查看
Ahelion
can you be more specific about the command?
trying this out:
mircea@tarhon:~/nxp/imx-yocto-bsp6/newbuild/tmp/deploy/images/imx8qmmek$ sudo uuu -b sd u-boot.bin
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.5.21-0-g1f42172
Success 0 Failure 1
1:3 1/ 1 [HID(W):LIBUSB_ERROR_IO ] SDPS: boot -f u-boot.bin
536 次查看
Harvey021
Harvey
