Hi NXP,
We tried to record from micfil mic on imx8mp evk without i.MX 8MIC-RPI-MX8 Board. (only use imx8mp evk)
We connect microphone on imx8mp evk board, and type following command in console.
root@imx8mpevk:~# arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: imxaudioxcvr [imx-audio-xcvr], device 0: XCVR PCM snd-soc-dummy-dai-0 [XCVR PCM snd-soc-dummy-dai-0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: imxaudiomicfil [imx-audio-micfil], device 0: micfil hifi snd-soc-dummy-dai-0 [micfil hifi snd-soc-dummy-dai-0]
Subdevices: 1/1
card 2: btscoaudio [bt-sco-audio], device 0: 30c20000.sai-bt-sco-pcm-wb bt-sco-pcm-wb-0 [30c20000.sai-bt-sco-pcm-wb bt-sco-pcm-wb-0]
Subdevices: 1/1
card 3: wm8960audio [wm8960-audio], device 0: HiFi wm8960-hifi-0 [HiFi wm8960-hifi-0]
Subdevices: 1/1
card 3: wm8960audio [wm8960-audio], device 1: HiFi-ASRC-FE (*) []
Subdevices: 1/1
arecord -f S16_LE -D plughw:1,0 -t wav -r 16000 -c 2 -d 30 ./test_mic_0.wav -vvv
Recording WAVE './test_mic_0.wav' : Signed 16 bit Little Endian, Rate 16000 Hz, Stereo
Plug PCM: Linear conversion PCM (S32_LE)
Its setup is:
stream : CAPTURE
access : RW_INTERLEAVED
format : S16_LE
subformat : STD
channels : 2
rate : 16000
exact rate : 16000 (16000/1)
msbits : 16
buffer_size : 8000
period_size : 2000
period_time : 125000
tstamp_mode : NONE
tstamp_type : MONOTONIC
period_step : 1
avail_min : 2000
period_event : 0
start_threshold : 1
stop_threshold : 8000
silence_threshold: 0
silence_size : 0
boundary : 9007199254740992000
Slave: Hardware PCM card 1 'imx-audio-micfil' device 0 subdevice 0
Its setup is:
stream : CAPTURE
access : MMAP_INTERLEAVED
format : S32_LE
subformat : STD
channels : 2
rate : 16000
msbits : 32
buffer_size : 8000
period_size : 2000
tstamp_mode : NONE
period_step : 1
avail_min : 2000
period_event : 0
start_threshold : 1
silence_size : 0
appl_ptr : 0
hw_ptr : 0
Max peak (4000 samples): 0x00007fff #################### 99%
Max peak (4000 samples): 0x000035d2 ######### 42%
Max peak (4000 samples): 0x0000368b ######### 42%
Max peak (4000 samples): 0x00003cf3 ########## 47%
Max peak (4000 samples): 0x000037e2 ######### 43%
Max peak (4000 samples): 0x00003925 ######### 44%
Max peak (4000 samples): 0x00003754 ######### 43%
Max peak (4000 samples): 0x00003c96 ########## 47%
Max peak (4000 samples): 0x000036df ######### 42%
Max peak (4000 samples): 0x00003aac ########## 45%
Max peak (4000 samples): 0x00003ea4 ########## 48%
Max peak (4000 samples): 0x0000333c ######### 40%
Max peak (4000 samples): 0x00003b63 ########## 46%
Max peak (4000 samples): 0x00003b83 ########## 46%
Max peak (4000 samples): 0x000039d0 ########## 45%
Max peak (4000 samples): 0x000037d9 ######### 43%
Max peak (4000 samples): 0x00004496 ########### 53%
Max peak (4000 samples): 0x000037c6 ######### 43%
Max peak (4000 samples): 0x00003862 ######### 44%
Max peak (4000 samples): 0x0000404a ########### 50%
Max peak (4000 samples): 0x00007fba #################### 99%
Max peak (4000 samples): 0x00007fbd #################### 99%
Max peak (4000 samples): 0x00007ff8 #################### 99%
Max peak (4000 samples): 0x00007ff1 #################### 99%
Max peak (4000 samples): 0x00007fc8 #################### 99%
Max peak (4000 samples): 0x00007ffc #################### 99%
Max peak (4000 samples): 0x00007fef #################### 99%
Max peak (4000 samples): 0x00007fc4 #################### 99%
Max peak (4000 samples): 0x00007fe7 #################### 99%
Max peak (4000 samples): 0x00007ffe #################### 99%
Max peak (4000 samples): 0x00007fe0 #################### 99%
Max peak (4000 samples): 0x00007feb #################### 99%
Max peak (4000 samples): 0x00007ffb #################### 99%
Max peak (4000 samples): 0x00007fd8 #################### 99%
Max peak (4000 samples): 0x00007fb5 #################### 99%
Max peak (4000 samples): 0x00007ff3 #################### 99%
Max peak (4000 samples): 0x00007fd1 #################### 99%
Max peak (4000 samples): 0x00007fe3 #################### 99%
Max peak (4000 samples): 0x00007fe2 #################### 99%
Max peak (4000 samples): 0x00007fe8 #################### 99%
Max peak (4000 samples): 0x00007fcb #################### 99%
Max peak (4000 samples): 0x00007fd3 #################### 99%
Max peak (4000 samples): 0x00007ff2 #################### 99%
Max peak (4000 samples): 0x00007ffd #################### 99%
Max peak (4000 samples): 0x00007fdf #################### 99%
Max peak (4000 samples): 0x00007fb6 #################### 99%
Max peak (4000 samples): 0x00007ff5 #################### 99%
Max peak (4000 samples): 0x00007fed #################### 99%
Max peak (4000 samples): 0x00007ffa #################### 99%
Max peak (4000 samples): 0x00007fe5 #################### 99%
Max peak (4000 samples): 0x00007ff7 #################### 99%
Max peak (4000 samples): 0x00007ff6 #################### 99%
Max peak (4000 samples): 0x00007fea #################### 99%
Max peak (4000 samples): 0x00007ff9 #################### 99%
Max peak (4000 samples): 0x00007ff0 #################### 99%
Max peak (4000 samples): 0x00007ff4 #################### 99%
Max peak (4000 samples): 0x00007fd6 #################### 99%
Max peak (4000 samples): 0x00007fcd #################### 99%
Max peak (4000 samples): 0x00007fec #################### 99%
Max peak (4000 samples): 0x00007fee #################### 99%
Max peak (4000 samples): 0x00007fe9 #################### 99%
I can hear white noise only.
From the dmesg, I can find audio input related messages as below:
root@imx8mpevk:~# dmesg -wH | grep mic
[ +0.007200] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ +0.001247] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ +0.001331] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ +0.000223] optee: dynamic shared memory is enabled
[ +0.009236] fsl-micfil-dai 30ca0000.micfil: failed to get core clock: -517
[ +0.007387] imx-micfil sound-micfil: snd_soc_register_card failed (-517)
[ +0.026438] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 62
[ +0.005262] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 63
[ +0.001105] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 64
[ +0.012273] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 65
[ +0.003231] #1: imx-audio-micfil
[ 3803.585506] audit: type=1006 audit(1642480201.729:5): pid=966 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=4 res=1
"get core clock failed" messages was shown, does it have some problem?
If the "get core clock failed" is cause of this problem, how can I fix it?
I attached dmesg.log file on this case, please refer that.
BR, kangsub
Solved! Go to Solution.
Hello Kangsub,
Unfortunately I cannot find much on my side, could you connect an osciloscope and check the data and clock lines?
Aldo.
Hi, Aldo.
I found the BSP version from uname command on console as following :
Linux imx8mpevk 5.10.35-lts-5.10.y+gef3f2cfc6010 #1 SMP PREEMPT Tue Jun 8 14:42:10 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux
And I confirmed dts file that I used from /proc/device-tree/model :
NXP i.MX8MPlus EVK board
Kangsub.
Thank you for sharing more information, could you try with the following:
arecord -f S16_LE -d 30 -r 16000 --device="hw:1,0" capture.wav -vvv
Aldo.
Hi Aldo,
When I enter the command you sharing, device did not work with following message:
root@imx8mpevk:~# arecord -f S16_LE -d 30 -r 16000 --device="hw:1,0" capture.wav -vvv
Recording WAVE 'capture.wav' : Signed 16 bit Little Endian, Rate 16000 Hz, Mono
arecord: set_params:1343: Sample format non available
Available formats:
- S32_LE
I tried recording test with following command :
arecord -f S32_LE -d 30 -r 16000 --device="hw:1,0" capture.wav -vvv
I attach console output log as below:
root@imx8mpevk:~# arecord -f S32_LE -d 30 -r 16000 --device="hw:1,0" capture.wav -vvv
Recording WAVE 'capture.wav' : Signed 32 bit Little Endian, Rate 16000 Hz, Mono
Its setup is:
stream : CAPTURE
format : S32_LE
subformat : STD
channels : 1
rate : 16000
msbits : 32
buffer_size : 8000
period_size : 2000
tstamp_mode : NONE
period_step : 1
avail_min : 2000
period_event : 0
start_threshold : 1
silence_size : 0
appl_ptr : 0
hw_ptr : 0
Max peak (2000 samples): 0x7fffec00 #################### 99%
Max peak (2000 samples): 0x3f3d6500 ########## 49%
Max peak (2000 samples): 0x43585c00 ########### 52%
Max peak (2000 samples): 0x33a0c600 ######### 40%
Max peak (2000 samples): 0x36e53800 ######### 42%
Max peak (2000 samples): 0x431dd200 ########### 52%
Max peak (2000 samples): 0x3bd6a900 ########## 46%
Max peak (2000 samples): 0x44a8db00 ########### 53%
Max peak (2000 samples): 0x38361c00 ######### 43%
Max peak (2000 samples): 0x39751600 ######### 44%
Max peak (2000 samples): 0x39484100 ######### 44%
Max peak (2000 samples): 0x36d82900 ######### 42%
Max peak (2000 samples): 0x4ac9cc00 ############ 58%
Max peak (2000 samples): 0x38fde700 ######### 44%
Max peak (2000 samples): 0x37ee7700 ######### 43%
Max peak (2000 samples): 0x405bbf00 ########### 50%
Max peak (2000 samples): 0x37524900 ######### 43%
Max peak (2000 samples): 0x3841de00 ######### 43%
Max peak (2000 samples): 0x3992e400 ######### 44%
Max peak (2000 samples): 0x3901ab00 ######### 44%
Max peak (2000 samples): 0x36b83f00 ######### 42%
Max peak (2000 samples): 0x3c1b3800 ########## 46%
Max peak (2000 samples): 0x38c6ef00 ######### 44%
Max peak (2000 samples): 0x35ace000 ######### 41%
Max peak (2000 samples): 0x3b2d0600 ########## 46%
Max peak (2000 samples): 0x3ae8b200 ########## 46%
Max peak (2000 samples): 0x3eb12100 ########## 48%
Max peak (2000 samples): 0x38f3df00 ######### 44%
Max peak (2000 samples): 0x3a3d6800 ########## 45%
Max peak (2000 samples): 0x3c54f800 ########## 47%
Max peak (2000 samples): 0x360bf200 ######### 42%
Max peak (2000 samples): 0x3b918e00 ########## 46%
Max peak (2000 samples): 0x3f9c1400 ########## 49%
Max peak (2000 samples): 0x33606500 ######### 40%
Max peak (2000 samples): 0x38988d00 ######### 44%
Max peak (2000 samples): 0x3a895000 ########## 45%
Max peak (2000 samples): 0x45517d00 ########### 54%
Max peak (2000 samples): 0x3c6ddd00 ########## 47%
Max peak (2000 samples): 0x3debe000 ########## 48%
Max peak (2000 samples): 0x3e1f5800 ########## 48%
Max peak (2000 samples): 0x3cd42c00 ########## 47%
Max peak (2000 samples): 0x392e7600 ######### 44%
Max peak (2000 samples): 0x3e096400 ########## 48%
Max peak (2000 samples): 0x38cbf400 ######### 44%
Max peak (2000 samples): 0x3d0b5100 ########## 47%
Max peak (2000 samples): 0x376df400 ######### 43%
Max peak (2000 samples): 0x36d88100 ######### 42%
Max peak (2000 samples): 0x40433e00 ########### 50%
Max peak (2000 samples): 0x44251900 ########### 53%
Max peak (2000 samples): 0x3b023900 ########## 46%
Max peak (2000 samples): 0x411ce200 ########### 50%
Max peak (2000 samples): 0x399ed100 ########## 45%
Max peak (2000 samples): 0x3bac2f00 ########## 46%
Max peak (2000 samples): 0x3444eb00 ######### 40%
Max peak (2000 samples): 0x3c2ac600 ########## 47%
Max peak (2000 samples): 0x45ce5c00 ########### 54%
Max peak (2000 samples): 0x33ea4600 ######### 40%
Max peak (2000 samples): 0x3e008a00 ########## 48%
Max peak (2000 samples): 0x41d88700 ########### 51%
Max peak (2000 samples): 0x3adaed00 ########## 45%
Max peak (2000 samples): 0x3d90ab00 ########## 48%
Max peak (2000 samples): 0x409bf500 ########### 50%
Max peak (2000 samples): 0x378baa00 ######### 43%
Max peak (2000 samples): 0x35eebd00 ######### 42%
Max peak (2000 samples): 0x48930100 ############ 56%
Max peak (2000 samples): 0x7fe60900 #################### 99%
Max peak (2000 samples): 0x7fdc3300 #################### 99%
Max peak (2000 samples): 0x7fdb5500 #################### 99%
Max peak (2000 samples): 0x7fff1300 #################### 99%
Max peak (2000 samples): 0x7ff83700 #################### 99%
Max peak (2000 samples): 0x7ff72a00 #################### 99%
Max peak (2000 samples): 0x7fc38a00 #################### 99%
Max peak (2000 samples): 0x7fe92d00 #################### 99%
Max peak (2000 samples): 0x7fffa000 #################### 99%
Max peak (2000 samples): 0x7fe61000 #################### 99%
Max peak (2000 samples): 0x7ff54f00 #################### 99%
Max peak (2000 samples): 0x7ffc1200 #################### 99%
Max peak (2000 samples): 0x7fe80700 #################### 99%
Max peak (2000 samples): 0x7ffe0400 #################### 99%
Max peak (2000 samples): 0x7fc60b00 #################### 99%
Max peak (2000 samples): 0x7fff9600 #################### 99%
Max peak (2000 samples): 0x7fcd4a00 #################### 99%
Max peak (2000 samples): 0x7ffc6300 #################### 99%
Max peak (2000 samples): 0x7ffc6200 #################### 99%
Max peak (2000 samples): 0x7fdd7400 #################### 99%
Max peak (2000 samples): 0x7fedee00 #################### 99%
Max peak (2000 samples): 0x7fed2600 #################### 99%
Max peak (2000 samples): 0x7ff38e00 #################### 99%
Max peak (2000 samples): 0x7ff45800 #################### 99%
Max peak (2000 samples): 0x7fea6a00 #################### 99%
Max peak (2000 samples): 0x7ff4b600 #################### 99%
Max peak (2000 samples): 0x7fe96300 #################### 99%
Max peak (2000 samples): 0x7ff9a800 #################### 99%
Max peak (2000 samples): 0x7fee9b00 #################### 99%
Max peak (2000 samples): 0x7ff5ea00 #################### 99%
Max peak (2000 samples): 0x7fef8c00 #################### 99%
Max peak (2000 samples): 0x7ff77900 #################### 99%
Max peak (2000 samples): 0x7fef7000 #################### 99%
Max peak (2000 samples): 0x7fd4b100 #################### 99%
Max peak (2000 samples): 0x7fe83c00 #################### 99%
Max peak (2000 samples): 0x7ffabe00 #################### 99%
Max peak (2000 samples): 0x7ffadb00 #################### 99%
Max peak (2000 samples): 0x7ff7b200 #################### 99%
Max peak (2000 samples): 0x7ffa8500 #################### 99%
Max peak (2000 samples): 0x7ff33b00 #################### 99%
Max peak (2000 samples): 0x7fda6c00 #################### 99%
Max peak (2000 samples): 0x7fd84200 #################### 99%
Max peak (2000 samples): 0x7fe08400 #################### 99%
Max peak (2000 samples): 0x7fd54900 #################### 99%
Max peak (2000 samples): 0x7ffc2e00 #################### 99%
Max peak (2000 samples): 0x7ff5f700 #################### 99%
Max peak (2000 samples): 0x7fbf1600 #################### 99%
Max peak (2000 samples): 0x7fd4ac00 #################### 99%
Max peak (2000 samples): 0x7fc7c000 #################### 99%
Max peak (2000 samples): 0x7ff88400 #################### 99%
Max peak (2000 samples): 0x7fdc2600 #################### 99%
Max peak (2000 samples): 0x7feed300 #################### 99%
Max peak (2000 samples): 0x7ff83200 #################### 99%
Max peak (2000 samples): 0x7ffc5600 #################### 99%
Max peak (2000 samples): 0x7fd82300 #################### 99%
Max peak (2000 samples): 0x7ffe3100 #################### 99%
Max peak (2000 samples): 0x7ff96300 #################### 99%
Max peak (2000 samples): 0x7ffdd900 #################### 99%
Max peak (2000 samples): 0x7ffa4400 #################### 99%
Max peak (2000 samples): 0x7ff87f00 #################### 99%
Max peak (2000 samples): 0x7ff43100 #################### 99%
Max peak (2000 samples): 0x7ff98e00 #################### 99%
Max peak (2000 samples): 0x7fedff00 #################### 99%
Max peak (2000 samples): 0x7fff9500 #################### 99%
Max peak (2000 samples): 0x7ffe1f00 #################### 99%
Max peak (2000 samples): 0x7ffb6d00 #################### 99%
Max peak (2000 samples): 0x7ff8b800 #################### 99%
Max peak (2000 samples): 0x7ff76100 #################### 99%
Max peak (2000 samples): 0x7feee200 #################### 99%
Max peak (2000 samples): 0x7ffc9400 #################### 99%
Max peak (2000 samples): 0x7ffc9800 #################### 99%
Max peak (2000 samples): 0x7ffd8500 #################### 99%
Max peak (2000 samples): 0x7ff2f600 #################### 99%
Max peak (2000 samples): 0x7ffce300 #################### 99%
Max peak (2000 samples): 0x7fff2400 #################### 99%
Max peak (2000 samples): 0x7ff79d00 #################### 99%
Max peak (2000 samples): 0x7ffe0f00 #################### 99%
Max peak (2000 samples): 0x7ffe0800 #################### 99%
Max peak (2000 samples): 0x7ffd7400 #################### 99%
Max peak (2000 samples): 0x7fff7a00 #################### 99%
Max peak (2000 samples): 0x7ffec000 #################### 99%
Max peak (2000 samples): 0x7ffffd00 #################### 99%
Max peak (2000 samples): 0x7ffbc000 #################### 99%
Max peak (2000 samples): 0x7ffce000 #################### 99%
Max peak (2000 samples): 0x7fff6100 #################### 99%
Max peak (2000 samples): 0x7ff5bc00 #################### 99%
Max peak (2000 samples): 0x7fff4000 #################### 99%
Max peak (2000 samples): 0x7ffe3700 #################### 99%
Max peak (2000 samples): 0x7ffe9600 #################### 99%
Max peak (2000 samples): 0x7ff6f900 #################### 99%
Max peak (2000 samples): 0x7fffed00 #################### 99%
Max peak (2000 samples): 0x7ffb5400 #################### 99%
Max peak (2000 samples): 0x7ffedc00 #################### 99%
Max peak (2000 samples): 0x7ffb2d00 #################### 99%
Max peak (2000 samples): 0x7ffdc400 #################### 99%
Max peak (2000 samples): 0x7fff8600 #################### 99%
Max peak (2000 samples): 0x7fff8d00 #################### 99%
Max peak (2000 samples): 0x7ffcc400 #################### 99%
Max peak (2000 samples): 0x7ffec300 #################### 99%
Max peak (2000 samples): 0x7ffeef00 #################### 99%
Max peak (2000 samples): 0x7ffcd100 #################### 99%
Max peak (2000 samples): 0x7ffe9f00 #################### 99%
Max peak (2000 samples): 0x7fff0e00 #################### 99%
Max peak (2000 samples): 0x7ffb6700 #################### 99%
Max peak (2000 samples): 0x7ffe9700 #################### 99%
Max peak (2000 samples): 0x7ffde000 #################### 99%
Max peak (2000 samples): 0x7ffe3c00 #################### 99%
Max peak (2000 samples): 0x7ff90500 #################### 99%
Max peak (2000 samples): 0x7ffea600 #################### 99%
Max peak (2000 samples): 0x7ff8e400 #################### 99%
Max peak (2000 samples): 0x7ff25200 #################### 99%
Max peak (2000 samples): 0x7ff6a700 #################### 99%
Max peak (2000 samples): 0x7ffd4b00 #################### 99%
Max peak (2000 samples): 0x7ff51600 #################### 99%
Max peak (2000 samples): 0x7ffc7a00 #################### 99%
Max peak (2000 samples): 0x7ffc2d00 #################### 99%
Max peak (2000 samples): 0x7ff78600 #################### 99%
Max peak (2000 samples): 0x7ffd3e00 #################### 99%
Max peak (2000 samples): 0x7ff5d600 #################### 99%
Max peak (2000 samples): 0x7ff99e00 #################### 99%
Max peak (2000 samples): 0x7ffd4500 #################### 99%
Max peak (2000 samples): 0x7fff4100 #################### 99%
Max peak (2000 samples): 0x7ffe5400 #################### 99%
Max peak (2000 samples): 0x7ffe2a00 #################### 99%
Max peak (2000 samples): 0x7ffbfa00 #################### 99%
Max peak (2000 samples): 0x7ff9b100 #################### 99%
Max peak (2000 samples): 0x7fffca00 #################### 99%
Max peak (2000 samples): 0x7ff94500 #################### 99%
Max peak (2000 samples): 0x7ff8c400 #################### 99%
Max peak (2000 samples): 0x7ffdd800 #################### 99%
Max peak (2000 samples): 0x7ff7f700 #################### 99%
Max peak (2000 samples): 0x7ffffc00 #################### 99%
Max peak (2000 samples): 0x7feefc00 #################### 99%
Max peak (2000 samples): 0x7fff2600 #################### 99%
Max peak (2000 samples): 0x7fedc900 #################### 99%
Max peak (2000 samples): 0x7ff84b00 #################### 99%
Max peak (2000 samples): 0x7ffc9d00 #################### 99%
Max peak (2000 samples): 0x7ff53e00 #################### 99%
Max peak (2000 samples): 0x7ffcd200 #################### 99%
Max peak (2000 samples): 0x7ffb5200 #################### 99%
Max peak (2000 samples): 0x7ff61c00 #################### 99%
Max peak (2000 samples): 0x7fff8e00 #################### 99%
Max peak (2000 samples): 0x7ff98900 #################### 99%
Max peak (2000 samples): 0x7ffefe00 #################### 99%
Max peak (2000 samples): 0x7ff8b000 #################### 99%
Max peak (2000 samples): 0x7ffaae00 #################### 99%
Max peak (2000 samples): 0x7ff6ed00 #################### 99%
Max peak (2000 samples): 0x7ffa0700 #################### 99%
Max peak (2000 samples): 0x7ffe6c00 #################### 99%
Max peak (2000 samples): 0x7ffc1400 #################### 99%
Max peak (2000 samples): 0x7ffb9500 #################### 99%
Max peak (2000 samples): 0x7ffd8800 #################### 99%
Max peak (2000 samples): 0x7ffb4500 #################### 99%
Max peak (2000 samples): 0x7fff9a00 #################### 99%
Max peak (2000 samples): 0x7ffd0f00 #################### 99%
Max peak (2000 samples): 0x7ffced00 #################### 99%
Max peak (2000 samples): 0x7ffed300 #################### 99%
Max peak (2000 samples): 0x7ffbfb00 #################### 99%
Max peak (2000 samples): 0x7ffd5500 #################### 99%
Max peak (2000 samples): 0x7ff8da00 #################### 99%
Max peak (2000 samples): 0x7ff74e00 #################### 99%
Max peak (2000 samples): 0x7ff81800 #################### 99%
Max peak (2000 samples): 0x7ffeec00 #################### 99%
Max peak (2000 samples): 0x7ffda200 #################### 99%
Max peak (2000 samples): 0x7ff52900 #################### 99%
Max peak (2000 samples): 0x7ff88c00 #################### 99%
Max peak (2000 samples): 0x7fffc500 #################### 99%
Max peak (2000 samples): 0x7ffba800 #################### 99%
Max peak (2000 samples): 0x7ffdea00 #################### 99%
And the output wav file plays only white noise still.
Kangsub.
Thank you for testing, actually the second test is the one we usually do for test, testing with 5.10.35 BSP, default device tree (imx8mp-evk.dtb), with microphone
https://www.adafruit.com/product/3492
root@imx8mpevk:~# arecord -f S32_LE -d 10 -r 48000 --device="hw:1,0" capture.wav -vvv
Recording WAVE 'capture.wav' : Signed 32 bit Little Endian, Rate 48000 Hz, Mono
Its setup is:
stream : CAPTURE
format : S32_LE
subformat : STD
channels : 1
rate : 48000
exact rate : 48000 (48000/1)
msbits : 32
buffer_size : 24000
period_size : 6000
tstamp_mode : NONE
period_step : 1
avail_min : 6000
period_event : 0
start_threshold : 1
stop_threshold : 24000
silence_size : 0
boundary : 6755399441055744000
appl_ptr : 0
hw_ptr : 0
Max peak (6000 samples): 0x30ce7100 ######## 38%
Max peak (6000 samples): 0x161cea00 #### 17%
Max peak (6000 samples): 0x066fc700 ## 5%
Max peak (6000 samples): 0x070dfc00 ## 5%
Max peak (6000 samples): 0x06bde300 ## 5%
Max peak (6000 samples): 0x05783000 # 4%
Max peak (6000 samples): 0x04088900 # 3%
Max peak (6000 samples): 0x02ea0100 # 2%
Max peak (6000 samples): 0x02c7b700 # 2%
Max peak (6000 samples): 0x01c11e00 # 1%
Max peak (6000 samples): 0x015fb400 # 1%
Max peak (6000 samples): 0x011c8300 # 0%
Max peak (6000 samples): 0x00febe00 # 0%
Max peak (6000 samples): 0x00d98d00 # 0%
Max peak (6000 samples): 0x00e02f00 # 0%
Max peak (6000 samples): 0x0163fc00 # 1%
Max peak (6000 samples): 0x00f8a700 # 0%
Max peak (6000 samples): 0x009a6300 # 0%
Max peak (6000 samples): 0x00a46200 # 0%
Max peak (6000 samples): 0x00b33900 # 0%
Max peak (6000 samples): 0x01711e00 # 1%
Max peak (6000 samples): 0x009f9500 # 0%
Max peak (6000 samples): 0x00cd3300 # 0%
Max peak (6000 samples): 0x36bf4100 ######### 42%
Max peak (6000 samples): 0x6bf24500 ################# 84%
Max peak (6000 samples): 0x7ffffb00 #################### 99%
Max peak (6000 samples): 0x01347700 # 0%
Max peak (6000 samples): 0x086e8200 ## 6%
Max peak (6000 samples): 0x6a2b3200 ################# 82%
Max peak (6000 samples): 0x0c089900 ## 9%
Max peak (6000 samples): 0x041d8400 # 3%
Max peak (6000 samples): 0x7f929300 #################### 99%
Max peak (6000 samples): 0x7d62b400 #################### 97%
Max peak (6000 samples): 0x1ec17d00 ##### 24%
Max peak (6000 samples): 0x118f9700 ### 13%
Max peak (6000 samples): 0x1905fc00 #### 19%
Max peak (6000 samples): 0x1f170a00 ##### 24%
Max peak (6000 samples): 0x222f0800 ###### 26%
Max peak (6000 samples): 0x22a0fd00 ###### 27%
Max peak (6000 samples): 0x22471100 ###### 26%
Max peak (6000 samples): 0x2103fe00 ###### 25%
Max peak (6000 samples): 0x20145600 ###### 25%
Max peak (6000 samples): 0x1e55af00 ##### 23%
Max peak (6000 samples): 0x1886dc00 #### 19%
Max peak (6000 samples): 0x7f878b00 #################### 99%
Max peak (6000 samples): 0x2ee17800 ######## 36%
Max peak (6000 samples): 0x123cf000 ### 14%
Max peak (6000 samples): 0x7f571300 #################### 99%
Max peak (6000 samples): 0x0e6b0700 ### 11%
Max peak (6000 samples): 0x0cb13600 ## 9%
Max peak (6000 samples): 0x094e1900 ## 7%
Max peak (6000 samples): 0x071d6e00 ## 5%
Max peak (6000 samples): 0x04d5d200 # 3%
Max peak (6000 samples): 0x02bd5e00 # 2%
Max peak (6000 samples): 0x01b05700 # 1%
Max peak (6000 samples): 0x319f4300 ######## 38%
Max peak (6000 samples): 0x1579f300 #### 16%
Max peak (6000 samples): 0x02087900 # 1%
Max peak (6000 samples): 0x7ea5bc00 #################### 98%
Max peak (6000 samples): 0x46f33c00 ############ 55%
Max peak (6000 samples): 0x00a60e00 # 0%
Max peak (6000 samples): 0x01560000 # 1%
Max peak (6000 samples): 0x019bf300 # 1%
Max peak (6000 samples): 0x0264a900 # 1%
Max peak (6000 samples): 0x0346df00 # 2%
Max peak (6000 samples): 0x03f2ab00 # 3%
Max peak (6000 samples): 0x03e9f300 # 3%
Max peak (6000 samples): 0x0425b400 # 3%
Max peak (6000 samples): 0x04b64700 # 3%
Max peak (6000 samples): 0x04d75600 # 3%
Max peak (6000 samples): 0x04fdff00 # 3%
Max peak (6000 samples): 0x04df3500 # 3%
Max peak (6000 samples): 0x0565be00 # 4%
Max peak (6000 samples): 0x06027200 # 4%
Max peak (6000 samples): 0x09d3af00 ## 7%
Max peak (6000 samples): 0x08fd2300 ## 7%
Max peak (6000 samples): 0x0b7ee800 ## 8%
Max peak (6000 samples): 0x06f23900 ## 5%
Max peak (6000 samples): 0x029f4a00 # 2%
Could you check for a possible faulty HW, a different microphone you could try with?
Aldo.
Hi Aldo.
My hardware team member did not accept your request that change to other microphone parts because following reason.
1. do not have other microphone part. (need much time due to internal process)
2. currently connected microphone part is worked well other platform before. (other AI platform board)
3. We confirmed that the microphone part work well in our custom board using NXP solution with similar configuration.
Is there any other consideration point of software?
Kangsub.
Got it, thank you for checking.
May I ask how are you connecting your mic to the EVK?
Aldo.
Hi Aldo,
I cannot attach any files to this site because internal security program.
We used EXP_CN port for connecting mic1 and mic2.
mic1 data pin is connected PDM_STREAM0, mic2 data pin is connected PDM_STREAM3.
When I had requested check this schematic to NXP Korea before, I received message the schematic did not have problem.
Kangsub.
Hello Kangsub,
Thank you for sharing, do not worry this should be enough.
I'll keep checking an update as soon as possible.
Aldo.
Hello Kangsub,
Aldo.
Hi Aldo,
Thanks for your support.
I'll foward your suggestion to our hardware team.
Best Regard,
kangsub
Hi Aldo,
Sorry for late response.
We were new year holiday in last week.
I will reply after sending your request to our HW teams.
kangsub.
Could you share the BSP version that you’re using for your test?
Which dts are you using, default?
Aldo.
