imx8mp jailhouse mmc2 print timeout
jimmyhua
1.392352] Warning: unable to open an initial console.
[ 1.397384] Waiting for root device /dev/mmcblk2p2...
[ 11.606455] mmc2: Timeout waiting for hardware interrupt.
[ 11.608900] mmc2: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 11.615066] mmc2: sdhci: Sys addr: 0xc4157200 | Version: 0x00000002
[ 11.621232] mmc2: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000001
[ 11.627399] mmc2: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
[ 11.633566] mmc2: sdhci: Present: 0x01e88a8e | Host ctl: 0x00000011
[ 11.639732] mmc2: sdhci: Power: 0x00000002 | Blk gap: 0x00000080
[ 11.645898] mmc2: sdhci: Wake-up: 0x00000008 | Clock: 0x000010ff
[ 11.652065] mmc2: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 11.658232] mmc2: sdhci: Int enab: 0x117f100b | Sig enab: 0x117f100b
[ 11.664399] mmc2: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000502
[ 11.670566] mmc2: sdhci: Caps: 0x07eb0000 | Caps_1: 0x0000b400
[ 11.676732] mmc2: sdhci: Cmd: 0x0000083a | Max curr: 0x00ffffff
[ 11.682899] mmc2: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0xffffffff
[ 11.689065] mmc2: sdhci: Resp[2]: 0x329f5903 | Resp[3]: 0x00d0ffff
[ 11.695232] mmc2: sdhci: Host ctl2: 0x00000000
[ 11.699482] mmc2: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0xc483d200
[ 11.705649] mmc2: sdhci-esdhc-imx: ========= ESDHC IMX DEBUG STATUS DUMP =========
[ 11.712899] mmc2: sdhci-esdhc-imx: cmd debug status: 0x2100
[ 11.718315] mmc2: sdhci-esdhc-imx: data debug status: 0x22d0
[ 11.723815] mmc2: sdhci-esdhc-imx: trans debug status: 0x23c0
[ 11.729399] mmc2: sdhci-esdhc-imx: dma debug status: 0x2400
[ 11.734815] mmc2: sdhci-esdhc-imx: adma debug status: 0x2510
[ 11.740315] mmc2: sdhci-esdhc-imx: fifo debug status: 0x2610
[ 11.745815] mmc2: sdhci-esdhc-imx: async fifo debug status: 0x2733
[ 11.751815] mmc2: sdhci: ============================================
[ 11.758202] mmc2: error -110 whilst initialising MMC card
[ 22.102455] mmc2: Timeout waiting for hardware interrupt.
[ 22.104900] mmc2: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 22.111066] mmc2: sdhci: Sys addr: 0xc4157200 | Version: 0x00000002
[ 22.117232] mmc2: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000001
[ 22.123398] mmc2: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
[ 22.129565] mmc2: sdhci: Present: 0x01e88a8e | Host ctl: 0x00000011
[ 22.135732] mmc2: sdhci: Power: 0x00000002 | Blk gap: 0x00000080
[ 22.141898] mmc2: sdhci: Wake-up: 0x00000008 | Clock: 0x000020af
[ 22.148065] mmc2: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 22.154232] mmc2: sdhci: Int enab: 0x117f100b | Sig enab: 0x117f100b
[ 22.160398] mmc2: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000502
[ 22.166565] mmc2: sdhci: Caps: 0x07eb0000 | Caps_1: 0x0000b400
[ 22.172732] mmc2: sdhci: Cmd: 0x0000083a | Max curr: 0x00ffffff
[ 22.178899] mmc2: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0xffffffff
[ 22.185065] mmc2: sdhci: Resp[2]: 0x329f5903 | Resp[3]: 0x00d0ffff
[ 22.191232] mmc2: sdhci: Host ctl2: 0x00000000
[ 22.195482] mmc2: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0xc483d200
[ 22.201649] mmc2: sdhci-esdhc-imx: ========= ESDHC IMX DEBUG STATUS DUMP =========
[ 22.208899] mmc2: sdhci-esdhc-imx: cmd debug status: 0x2100
[ 22.214315] mmc2: sdhci-esdhc-imx: data debug status: 0x22d0
[ 22.219815] mmc2: sdhci-esdhc-imx: trans debug status: 0x23c0
[ 22.225399] mmc2: sdhci-esdhc-imx: dma debug status: 0x2400
[ 22.230815] mmc2: sdhci-esdhc-imx: adma debug status: 0x2510
[ 22.236315] mmc2: sdhci-esdhc-imx: fifo debug status: 0x2610
[ 22.241815] mmc2: sdhci-esdhc-imx: async fifo debug status: 0x2733
[ 22.247815] mmc2: sdhci: ============================================
[ 22.254053] mmc2: error -110 whilst initialising MMC card
is mmc2 interrupt some error?
Peng_Fan
1.392352] Warning: unable to open an initial console.   ==> You last thread shows ttymxc3 is ok for your inmate, but here it gone?
[ 1.397384] Waiting for root device /dev/mmcblk2p2...   ==> please make sure the interrupt of sdhc controller you assigned to inmate is correct. Check the inmate cfg file. Also disable the sdhc in root cell device tree.
So make sure mmc2 clock is set up by root cell(inmate does not has capability to touch clock controller, so need root cell to config it), and mmc2 interrupt and memory is correctly set up in inmate cell and inmate device tree.
Kernel & Virtualization Engineer
Alejandro_Salas
Hello @jimmyhua
Are you using the EVK or custom board?
Could you please share more steps to try to reproduce it by my side?
Salas.
