imx8mp hdmi phy pll timings
linchen4
Hello Community:
I am attempting to add support for additional HDMI output timings, such as 3840x2160p30, I have found that these timing are not supported because the required pixel clock value is not present in the hdmi-phy samsung_phy_pll_cfg timings table.
Could you provide a tools which can generate a register configuration of “samsung_phy_pll_cfg” through timing?
