[imx8mp]How could I make the kernel config of "Fully Preemptible Kernel (RT)" configurable?
1,422 次查看
curly_sun
Hi there,
forgive my poor English.
=====Here is the situation=====
I'm using the imx8mp-lpddr4-evk board and Yocto 4.0 kirkstone for some work.
Basicly,  I'm working with the imx-image-full recipe and there is linux-imx recipe in there.
When I check the linux kernel config with "$ bitbake linux-imx -c menuconfig", I found that there is no "Preemption Model -> Fully Preemptible Kernel (RT)" option to select.
====Here is my questions=====
Did I use the wrong image recipe or linux recipe? I saw some posts there, they used recipe like imx8mpevk-real-time-edge. But I can't find it in my Yocot Project.
Should I use some patches? I also saw some posts there, they used some patches which I even didn't know where to get them.
Are there some documents to tell you how to do it? Or some posts. I checked some documents from NXP(not all), but nothing found. Did I miss something important?
Thanks for your help.
4 回复数
1,401 次查看
khang_letruong
Senior Contributor III
Hi @curly_sun ,
> It is because the feature has some dependency. When you are in the menuconfig, you could hit the / key and enter the keyword PREEMPT_RT for example to see its dependency list.
Suppose that you expect to use the iMX8MP for some realtime task, you could take a look at here : https://www.nxp.com/design/software/development-software/real-time-edge-software:REALTIME-EDGE-SOFTW...
And the relevant Yocto project: https://github.com/nxp-real-time-edge-sw/yocto-real-time-edge
Also, associated kernel's defconfig of above Yocto project could be found here : https://github.com/nxp-real-time-edge-sw/real-time-edge-linux/blob/linux_5.10.y/arch/arm64/configs/i...
Khang
1,385 次查看
curly_sun
Hi @khang_letruong
Thanks for your help and so many useful informations!
These informations of nxp-real-time-edge-sw/yocto-real-time-edge you just tell me is exactly what I needed.
I will start with the documents about Real-Time Edge and try those new things for me in my works.
Thanks again!
1,373 次查看
khang_letruong
Hi @curly_sun ,
Hope that the Real-Time Edge resolves your issue.
Khang
1,397 次查看
Bio_TICFSL
Good!
